Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Case 450 crawler won't move
curtis larson
10-29-2012 19:19:09
Working on a steep grade I will bet you stept on the brake before changing direction . your brake plunger on your trans. stuck in the neutral position.
chaser
10-30-2012 04:30:27
 Re: Case 450 crawler won't move in reply to curtis larson, 10-29-2012 19:19:09
The brakes have never worked, so I have never pushed them in the 4 years I have owned it. Thanks for the suggestion though.
chaser
10-30-2012 08:21:19
 Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 04:30:27
I can tell you that my motor has never ran so smooth since I have owned it, like there is no load what so ever. I will check the gauages and pressures after work and post results.
Any other ideas??
Thanks
chaser
10-30-2012 11:00:34
 Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 08:21:19
Tranny pressure was 225 converter pressure 65.
Does that mean the charging pump is good? Why wont this thing move all the sudden?
Dkat
01-08-2013 09:02:54
 Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 11:00:34
Did, you figure it out? mine just started the same thing, like it's locked in two gears at the same time?
Copyright © 1997-2015 Yesterday's Tractor Co.
