| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Case 450 crawler won't move
[Return to Forum]
| Author |
[Modern View]
| Chaser
10-29-2012 16:31:28
75.235.226.128
Was on a steep incline and backed down. When I shifted to forward it would not move. That was the second time today it happened, the first time I thought it was low on fluid and being on the incline so I added fluid and it worked fine until I was up there again. Now it won't move at all. Have tranny pressure and converter pressure. The drive shaft is not turning. Can anybody help me? |
| george md
10-30-2012 20:37:38
209.213.167.201
Re: Case 450 crawler won't move in reply to Chaser, 10-29-2012 16:31:28
| Chaser, Sounds like the fiber ring that connects the torque converter to the flywheel has lost it's teeth. That is why you have pressures and no rotating driveshaft. Drop converter out the bottom ,replace ring ,and reinstall converter. george |
| chaser
10-31-2012 04:25:32
63.254.17.26
Re: Case 450 crawler won't move in reply to george md, 10-30-2012 20:37:38
| | So I should be able to crawl underneath and crank motor over to verify if the converter is turning or not? If not than the ring is broken? Thanks George I will check this out after work today. |
| Morgan Flowers
10-30-2012 07:46:21
97.89.65.86
Re: Case 450 crawler won't move in reply to Bill Lisbon, 10-29-2012 16:31:28
| Quoting Removed, click Modern View to see
I was going to suggest the hydraulic suction hose on the bottom of the transmission, but if you have pressure that shouldn't be the problem. But it happened to our 450b a few years ago. It would build some pressure but wouldn't move and it turned out that the hose was old and being sucked flat. |
| curtis larson
10-29-2012 19:19:09
184.10.178.219
| Working on a steep grade I will bet you stept on the brake before changing direction . your brake plunger on your trans. stuck in the neutral position. |
| chaser
10-30-2012 04:30:27
63.254.17.26
Re: Case 450 crawler won't move in reply to curtis larson, 10-29-2012 19:19:09
| The brakes have never worked, so I have never pushed them in the 4 years I have owned it. Thanks for the suggestion though. |
| chaser
10-30-2012 08:21:19
63.254.17.26
Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 04:30:27
| | I can tell you that my motor has never ran so smooth since I have owned it, like there is no load what so ever. I will check the gauages and pressures after work and post results. Any other ideas?? Thanks |
| chaser
10-30-2012 11:00:34
63.254.17.26
Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 08:21:19
| | Tranny pressure was 225 converter pressure 65. Does that mean the charging pump is good? Why wont this thing move all the sudden? |
| Dkat
01-08-2013 09:02:54
72.45.82.75
Re: Case 450 crawler won't move in reply to chaser, 10-30-2012 11:00:34
| Did, you figure it out? mine just started the same thing, like it's locked in two gears at the same time? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
