| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: 977 h caterpillar idler wheels
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| NCWayne
10-29-2012 07:27:30
69.40.232.132
Just rebuilt he undercarriage on a 977 awhile back that had the same problem. That said, you should be able to weld up the crack without any problems. If the crack is running with the joint that holds the rim on, simply grind it out as much as possible and reweld. If there are any other cracks radiating from it and across the side faces of the idler then drill a hole at the end of them, V them out, and weld. For no more welding than than your going to be doing you won't have anything to worry about with pressure building up inside the idler, etc like would happen when laying on the HUGE, multiple, weld beads with a machine torch when rebuilding one. |
[Reply] [No Email] | |
| Stick welding
10-29-2012 18:23:11
96.53.210.246
Re: 977 h caterpillar idler wheels in reply to NCWayne, 10-29-2012 07:27:30
| It's not a big deal to cut a hole and then weld it back in. It doesn't have to be real strong just tack a piece or bar or a bolt on it, so you don't drop it inside the idler. I welded a ripper frame crack for a guy and it cracked right down the weld from the build up of pressure inside. I happened to have some 3/16" 11018 that I used. |
| NCWayne
10-29-2012 20:14:16
69.40.232.132
Re: 977 h caterpillar idler wheels in reply to Stick welding, 10-29-2012 18:23:11
| Most guys have never seen a 3/16" rod, and don't have a power supply with nearly enought amps to burn one. That being the case, a couple of passes with a 1/8" 7018 more than likely won't build as much heat as one pass with the much larger rod. That said, yeah, I know what your saying but my thoughts were that a hole cut and then welded back up by some one that doesn't do alot of cutting and welding would tend to be more of a problem (read new crack waiting to happen) than just not worrying about it. If it were me I'd much rather drill a small hole. In this case 1/4" diameter should be a gracious plenty as a vent, and much easier to weld up than a plate cut out of the side. Too a small hole is far less likely to propulgate a crack due to the round shape than a torch cut hole. |
| Stick welding
11-06-2012 10:08:28
198.53.25.107
Re: 977 h caterpillar idler wheels in reply to NCWayne, 10-29-2012 20:14:16
| The patch doesn't need aNy strength. It just keeps dirt and water out of the idler. If someone has enough skill to build up the idler, they can weld the cut out back in. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
