Case 1494 4WD tractor
Dave Sayer
10-25-2005 19:41:41
Can anyone tell me about a tractor that I own. All I know is that it is a CASE 1494 4 wheel drive. Can you tell me the HP and anything else relevant.
baz
10-25-2005 23:17:06
 Re: Case 1494 4WD tractor in reply to Dave Sayer, 10-25-2005 19:41:41
The Case sales brochure states 85 engine hp. It is a turbo charged engine. The 4wd drive axle is a Carraro brand [Italian]. You will either have a 12 speed synchromesh or hydra-shift transmission [ the hydra-shift has a range box 123+R, plus 4 shifts you can make on the move without using the clutch, up or down. You have a front mounted hydraulic pump [off crank], easy to replace or up spec. A 2 speed pto box [540 and 1000 RPM]. Parts for these tractors are no problem.
Tom (Ks)
10-25-2005 20:25:38
The 1494 has 75HP.
Darryl Digby-Smith
07-02-2006 05:30:58
 Re: Case 1494 4WD tractor in reply to Tom (Ks), 10-25-2005 20:25:38
The case 1494 are 85 H.P.@2200rpm.305nm or222.7ftlbs of torque@1600rpm.
