Case 220 starter/generator wiring diagram or help
RainFade
06-18-2005 18:15:39
I'm the proud new owner of a Case 220 lawn tractor.
The only thing about it needing immediate attention is the fact it won't charge.
It works fine as a starter but is not appearing to charge (digital meter shows voltage a few tenths lower running that shut off) P.O. told me he had to jump or trickle to start her... sure enough.
The terminal on the regulator was not connected, I assume it goes to A
F is connected to F on generator/starter.
L is not connected, does it Need a lamp to work ?
I've been spinning wrenches on all sorts of stuff for years and have done component level repair on pc's and peripherials for a living but I have to admit my generator theory is non existant and I could REALLY use some help.
I have googled until blue in the face and have looked around here but am not finding the info, honest I don't waste bandwidth until I fail to find it myself :-)
Thanks in advance,
Brian
Klyde
06-19-2005 05:32:22
 Re: Case 220 starter/generator wiring diagram or h in reply to RainFade, 06-18-2005 18:15:39
A terminal goes to the "starter" cable at the solenoid, as that is the armature wire when running. B terminal may be on the bottom ,you didn't metion that one. That goes tosolenoid B+. L terminal can be used to feed the ign switch. hth
sc man
06-19-2005 17:53:29
 Re: Case 220 starter/generator wiring diagram or h in reply to Klyde, 06-19-2005 05:32:22
L is for lights
