Hay elevator pulley diameter
Oliver1800A
03-24-2005 13:52:29
I have a Case E-2 elevator with a 1750 RPM 3/4 HP motor on it. The jackshaft double reduction pulley are gone. I still have the original 12 driven pulley. My question is what size drive pulley on the motor is needed for hay bales on the elevator. I have a book but no specifics about the pulleys. Anyone done the change from the original gas motor or any info on the pulleys and belts used would be helpful.
Klyde
03-25-2005 16:21:05
 Re: Hay elevator pulley diameter in reply to Oliver1800A, 03-24-2005 13:52:29
OK here goes, finally mesured mine. BUT I use it for ear corn and my double pully is still there and it runs plenty fast. 1725 RPM motor with 5 3/4" sheave to a 14" with a 6" (double reduction sheaves) to a 14" sheave. I hope this helps you figure out what you need.
Oliver1800A
03-25-2005 20:32:17
 Re: Hay elevator pulley diameter in reply to Klyde, 03-25-2005 16:21:05
Klyde,
Thank you. That will help for my double reduction is missing and I had nothing to go from. SInce I have to make my own double, I can try to size it for my needs. I just need a place to start. According to my calculatons, I need to get the driven pulley at 160 RPM for hay. This is a perplexing problem that I figured others have crossed thsi path as well.
I appreciate the help.
DAVE
