Re: Case 580 Super E Backhoe Transmission fluid ?
Terrance
09-01-2004 18:24:18
The Case Manual calls for Case TCH Fluid, in the power shuttle 8 qts, master cylinders, and the hydraulic system 24 gal. Most major brands of Tractor Hydraulic Oil are suitable replacements for Case TCH Fluid. The Transaxle(4speed transmission/rear axle) 20 qts, transfer case(4x4) 1 pt, front drive axle(4x4)7 qts,and planetary 1.5 qt each, all use Case FDL fluid.
That is a great tractor take care of it and it will last a long time with little cost to you.
Hope this helps Terrance
