Well I pulled the rocker arms on my Case vac.
Nicholaus Sowde
02-07-2004 12:48:21
Well I pulled the rocker arms on my Case vac. Is the rocker arms supposed to come apart in the middle and the sixth push rod from the front was shorter and bigger around then the others. Do you all think someone just put that one in or what. There was a dead lizard on top of number one piston to.Thanks
Joe (Wa)
02-07-2004 16:05:46
 Re: Well I pulled the rocker arms on my Case vac. in reply to Nicholaus Sowder, 02-07-2004 12:48:21
I am seeing two different diameter pushrods in Vac. Both same length @ 11-5/16". Smaller rod (earlier?)is 1/4" dia, with a slightly larger cup @ the adjustment screw and a knob on the lifter end. Larger rod (later?) is 5/16" w/o the lifter end knob.
Yes the rkr arm is two piece.
Don't know what you can do with the lizard. They make great black bass bait.
Joe
