TractorLinks.com
Show Parts for Model:
Case charging system
paul
06-04-2003 16:44:30
Do older model Case tractors have posititve or negative ground?
Jason
06-20-2003 18:04:37
 Re: Case charging system in reply to paul, 06-04-2003 16:44:30
I'am working on a case sc with a mag does it a pos. or neg. ground
Mike from Canada
06-05-2003 00:09:20
if the tractor uses magneto ignition its positive ground. if its points ignition its negative ground. my 49 VAC has neg. ground w/ points ign.
hope this helps.
mike
george md
06-06-2003 20:31:07
 Re: Re: Case charging system in reply to Mike from Canada, 06-05-2003 00:09:20
Mike ,
dealers service manual says positive ground
with either ignition .And I have had one since
1959, good little tractor.
george
george md
06-04-2003 19:56:16
Paul,
The operators manual for 300 says positive ground .
george
Leroy
06-06-2003 06:08:08
 Re: Re: Case charging system in reply to george md, 06-04-2003 19:56:16
Orignal on 300 a 6 or 12 volt system?
george md
06-07-2003 09:46:31
 Re: Re: Re: Case charging system in reply to Leroy, 06-06-2003 06:08:08
Leroy,
6 volt system except diesel model ,and it
is 12 volt .
george
Mike Schotte
06-04-2003 16:50:35
Paul,
I've always heard that all Racine built Case tractors have negative ground systems and that all Rock Island built Case tractors have positive ground electrical systems.
My SC and DC are negative ground. The VACs are positive ground. What model are you wondering about??
-Schotte
paul
06-04-2003 19:13:25
 Re: Re: Case charging system in reply to Mike Schotte, 06-04-2003 16:50:35
I'm asking for a friend, I just called him and all he knows is that it is a 54 model 300.
todd
06-06-2003 18:01:56
 Re: Re: Re: Case charging system in reply to paul, 06-04-2003 19:13:25
Rip all of that old electical crud of the 300 and convert it to 12 volt negative ground (standard). I did my 46 SC with a new alternator and lights, including flasher and rear work light for under $100.00. If you use the tractor at night or in traffic you will never regret it. You can get the instructions to do it from the link on the YT site that sells electronic ignition conversions. I have not installed one of those as I can still gap a set of points!
