Working on a 310 that we are raising from the dead. Eagle hitch lifts just fine, but will not
lower. I can push down on the eagle hitch arms with the valve in the lowering position till the
front axle raises up, but the eagle hitch will not lower. Cracked the hydraulic line to the valve
to let the oil out, and it goes down just fine. Where do I dig into the valve to find the load
check? If the check is not stuck, where do I look next?
