karl h
when i step on the inching petal the tractor comes to a dead stop almost like it is being held. sometimes if i let up a little on the inching petal the tractor will start to roll like it's in neutral (what i would expect to happen when i push the inching petal to the floor)the tractor is jumpy when i let out the inching petal a swell. I have replaced the c1-c44 swap switch and it isn't much better. I don't understand what would make it feel like the tractor is being held instead of being in neutral...
Karl, I have not worked on many 94 series but I have had different goofy things happen when the relay circuit board goes bad. I would do some testing to see if the solenoids on the control valve are on and off when they are suppose to be, the service manual will show what ones are activated for each shift position. Rod.
