I got my VAC in november. It is a 51 with heavy oil only in the gearbox/rearend. I checked it when i bought it and I am sure it was right at full. The gear oil is so clean and green I am sure the guy must have changed it right before he sold it to me. Now when i check it, it is 1" above the notch on the stick. I must have read it wrong. I dont think 30 degree temp change would account for that much of a rise, or could it? I don't think hydraulic oil from that chamber is migrating to the rear end as I have not had to add any there either.
Anyway, does it hurt to overfill? And where is the oil line in the tranny? The reason I ask is I also have an axle seal leaking. If the rear is overfull would it push it out the axle? Only the right one is leaking. Finally, I saw on a facebook post where a guy is putting 2 seals on because the new ones are thinner? Is he right on that?
