This is part two of my 51 vac running slightly rough when light switch is pulled out to 2nd or 3rd position. I looked at the wiring diagram and traced it back one more time. It all looks right and the wires are in great shape. This is assuming on the light switch the wire at the end of the fuse goes to the ammeter, the middle top goes to the lights, and the one down by the resistor goes to the generator. This is how it looks in the diagram. I then started with the trouble shooting diagram. Step 1, with the tractor off, pull turn on the lights. Ammeter should show discharge. Failure at step one, I think. The needle jiggles just a little but doesn"t show discharge. THen, I think, well I have all LED"s so maybe they don"t draw enough. THen I think, the red blinking light is not led so i turned it on with the lights figuring that should draw enough to make the needle move, but it did not. So, I would say I need a new ammeter. That brings up the idea of replacing it with a volt meter. Will a volt meter work with that charging set up? and with pos ground. Thanks again to all who have chimed in in the past. I have another problem, but that is another post.
