Walter Buller
Okay. I put a new fuel pump on this tractor and now it cranks up and runs. However, it smokes pretty bad at high rpm's, something it did not previously do, and doesn't have much power. Plus, raw diesel is squirting out of the connection between the exhaust manifold and the exhaust pipe. I removed the injectors and found that there were no copper compression seals in the bottom of the ports in the head. I never heard of a diesel engine that did not require copper compression seals in the bottom of the ports. But apparently this tractor didn't have any when I bought it several years ago because this is the first time I've removed the injectors, and the tractor has done a good bit of bushogging for me up until just recently and ran just fine until the fuel lift pump stopped working. So I put a copper seal in each hole, put the same injectors back in place, cranked the tractor, but that made no difference. I'm still getting raw diesel blowing out of the exhaust manifold, as well as seeping up into the depression in the head where each port is. I took the injector that was leaking diesel on top of the head and had the tip replaced again. Now it doesn't leak when the tractor is running, but the one closest to the driver does. I'm having the other 2 injectors checked this afternoon. I already had the injector pump checked. My questions at this point are: Are David Brown 885 injectors not supposed to have compression seals at the bottom of the injectors? Could there be any other reason that raw diesel is spraying out of the exhaust manifold connection to the exhaust pipe, other than a "peeing" injector?
