Case SC brakes
ptosean
Hey guys! So I've got a 1953 Case SC with
disc brakes. They were seized up pretty
hard. When I went to take them apart I
started with the adjuster/linkage which
snapped right off. So I let the pieces soak
for a while and I finally got it all apart.
The actuators are apart, all the balls look
good, I've got one broken spring, but I
think what the problem was was that two
pieces that pull on the actuator were
completely locked up on both sides and I had
to cut the bolts that connected them. Any
idea how to find those parts other than
salvage? Not having much luck online.
Thanks!
Don is a great guy and should have what you need. If for some reason he doesn't have what you need Larson Imp near Cambridge Mn. should have what you need, their number is 763 689 1179. Ask for Mike for best results.
I bought a bag of assorted automobile drum brakes parts at an auto parts store. The springs are the same as inside the Case SC brakes. The spring pins were too long and had to cut them off. There are two different size sets of balls in there. I bought hardened stainless steel ones from McMaster Carr.
