430 brake issue
Don Rudolph
What would cause a 430 to suddenly lock up the right side brake assembly while sitting for a few days? Brake linkage is definitely engaged and tractor cannot move off the spot. Thanks for your help. Don
My 530 would do that also,put in all new OEM linings,surfaced the flat parts,took a light cut on the steel drum that the band grips on,all new springs and balls,they worked better than new!! Until I left it in the shed for a few weeks,same problem as before.They must draw moisture or something.I think they need to be used on a more regular basis.Good luck!!
