Have gauge need adapter
ScottNC
Bought the cheap Harbor Freight compression tester for diesels, $24 Saturday. None of the adapters work on DB88's AD3/55. If any one has an unusable injector they'd be willing to part with I'm looking.
Old tractor is starting much better after putting around five hours on it running a bush hog. Cold start-up is still not great.
The 20pc kit is mainly for glow plug engines..
..you needed the big kit.. I pretty sure it has the adaptor.
An adaptor tool is gonna run around 60.00>> Lang M21
My thoughts too. When cold there is a bit of blow-by. After running it for three hours not a drop of oil came out of the blow-by tube. Didn't have a hose on hand that fit the tube so figured there'd be a oily mess, but no. Didn't check again for blow-by while in use.
(quoted from post at 03:24:38 07/24/18) The 20pc kit is mainly for glow plug engines..
I'll make something. Would rather an unusable injector came my way first. I ran into an old tractor guy (he's going to paint my dash) who seems to be in the loop so to speak. Thought he might know someone who knows someone.... :roll:
(quoted from post at 13:52:05 07/24/18)
I have the more expensive HF kit and it has the proper adapter, HOWEVER, the slots were a bit to narrow for the 188 injector studs, hated to do it to a new adapter but it fits after a bit of die grinder application.
