New to me 970, brakes haven't worked since I got it. Starting to tear into them. The large arm on top of the brake housing, has the slave cylinder on it and the actuator lever goes into it. Both of mine appear to be stuck in an extended position. I was able to free one of them up a little bit by hitting it some with a hammer. The other one won't budge.
Can that pin that holds the arm on just be driven out? What's holding it in place? I'm thinking I should drive those pins out to see if I can free up the arms. May not be a bad idea to replace the slave cylinders while I've got it off too. Neither of them look that great.
