ben brown
have question customer bush hogging drags 20 ft mower over a hump sudden stop no pto no hyd..now last time he did this it sheared the splines out the flywheel.. well fingered he did it again split the tractor and splines are good .. so my question the pto shaft turns easy can i pull the pto shaft that drive the hyd pump and rear pto out the front with out causing any problem appears that it can be done that way so as to check the splines on the rear of drive shaft .. also if the gear... coupler that drive the hyd pump is bad can i get to it from the rear
