Loader on 1030 CASE
Lamont
Is there any way to plumb a joystick control for a loader on a 1030 CASE that will allow both SCV's and the 3-point to be used in conjunction with full loader control? Scratching my head. Thanks in advance for any help.
Never done a joystick, but a 3 valve control, hooked into one remote, left the other free,
There is a pipe or hose that comes from the hydraulic pump,take it off the hyd.pump and run a 3/4'' hose to your loader valve inlet port and run the return back to the hose that you took off the tractor pump.
