IUredcase
New User
Does anyone know the size of the injectors on a 2290? Were some pencil or screw in style? How much fuel can you safely push through the stock injectors when you turn the pump up for farmstock pulling?
Thanks,
JM
2290's all had screw-in injectors. I know very little about tractor pulling but I am sure the injectors will handle all the fuel that a stock pump can deliver. If you put
a bigger pump on injectors from a 2590 will fit in those heads. Rod.
