homesteader1954
Hi...has anyone taken a 970 standard trans model and cab and rearend from the flywheel back and married it to a 1070 motor. I ran into a clutch problem...the clutch is 14 inch on the 970 and the pressure plate is smaller. The 1070 uses a 15 inch...
Will the 15 inch clutch and pressure plate fit into the bell housing of the 970? The 970 flywheel bolts to the 1070 motor...has anyone heard of any problems with this other than the bolt holes not being far apart enough to mount the 1070 pressure plate.
Any suggestions...??
