When I would mow under load; I would get the engine loosing rpm and if I did not disengage the mower the engine would die.
I have inspected gas tank with camera, cleaned the fuel shut off under fuel tank, checked the fuel flow after fuel filter, and replaced the electric shut off valve on carburetor and yet under extreme load I get a slight
miss. Drops 100=200 rpms. It has a electronic ignition instead of points but the original coil.
I am going to replace spark plugs and clean air filter but any suggestions on where to go next well be much appreciated. I have been using gasoline with 10% alcohol.
Tractor has no misses when rpm's are keep under 1500rpm. But with the governor kicked in and running 1500-1700 rpms I get that miss. Thank you for your help John
