I have had issues with the relief valve on about a 1967 830 CK loosing pressure over the years. I generally add shims and correct the problem temporarily, but I believe something is wrong in the valve. I have the shop manuals and have replaced the springs sleeve, piston, and piston assembly in the valve located under the 1 1/4 plug under the hydraulic valve. Can anyone elaborate on the exact position of the o-rings in the valve. The parts book shows two 5/8 X 3/4 X 1/16 O-rings and a seal. I know one goes in the top of the sleeve above the piston assembly, but I cannot see where the others go. Any assistance would be greatly appreciated....
