TractorLinks.com
Show Parts for Model:
Eagle Hitch Sickle Mower PTO
connor9988
06-11-2018 18:27:25
I am on the fence about trying to get my Eagle Hitch mower fixed up and running. It could be a real money pit for a mediocre mower (needs new bar, sickles,guards, belt, PTO shaft). I guess what will determine if I continue is if I can find the front telescoping portion of the PTO shaft. Looking through some that are laying around here and none are the same. The telescoping part I am speaking of is the front half that connects to the tractor. It is hollow where all the others I have found are solid on the tractor side. Mine is broken/decayed beyond repair.
Anyone have any ideas/leads?
kevinthefixer
06-12-2018 19:42:00
 Re: Eagle Hitch Sickle Mower PTO in reply to connor9988, 06-11-2018 18:27:25
Quoting Removed, click Modern View to seeYup, first you'd lose all your fillings then your teeth would vibrate out. Either take it to a driveshaft shop or forget it. It would eat up your new U-joints too.
connor9988
06-12-2018 21:26:53
 Re: Eagle Hitch Sickle Mower PTO in reply to kevinthefixer, 06-12-2018 19:42:00
I agree. I think I will abandon this potential project. If anyone is interested in it for parts donor please let me know.
oldproudvet
06-12-2018 17:37:10
I've got an EDSC-7 that's complete, well wore but usable. I'll never get to it, email open. West central MN
RJKeith
06-12-2018 04:24:24
Can you find the hollow tube for the back end that fits? If so and it has the yoke, you can buy a matching U joint and matching PTO yoke. Of course it is more money into the pit.
connor9988
06-12-2018 06:08:56
 Re: Eagle Hitch Sickle Mower PTO in reply to RJKeith, 06-12-2018 04:24:24
The back u-joint connects to a cast piece that is threaded onto the mower flywheel. Looks like a Case specific part. I could take it apart at the u-joint and keep the back half of the joint with new PTO shaft from there on forward. I was also considering getting replacement tubing for the front half and welding a new front u-joint and PTO coupling on the front. I am curious if it would produce much vibration if it wasn't exactly spot-on center? (eyeballing it)
I have posted a picture of the back half of the PTO shaft.
casecollectorsc
06-12-2018 15:29:00
 Re: Eagle Hitch Sickle Mower PTO in reply to connor9988, 06-12-2018 06:08:56
My son and I have 12-15 of those mowers...maybe one of these would be easier to fix. Maybe I should sell one...E SD.
