So I install a new starter button. Picked up 2 different ones which turned out to be good since one was bad right out of the box. Got it fired up and noticed the alternator was not working. Found belt tensioner was loss due to a broken bolt. Fixed that and got the belt tight. Still no charge. Tried a few things and finally got to work. The 2 wire plug the #1 wire was not making good contact so which I pull the plug out and put it back in it started to charge. But now it will not shut down at the switch. Tried a couple of things that in the past have worked just fine. Tried the ballast resister thing to make it shut down and that did not work. Put the diode back in and that still did not work. So I now have to shut of down by shutting off the gas. Oh well at least it is now ready to rake hay once it is dry enough
