onthemoney
New User
Hello,
I own a 1964 Case 530 CK Diesel with the Case-o-Matic transmission.
Fluid is low according to dipstick.
Where is the fill plug.
Any help would be appreciated. Pics a plus!
Thanks much
Remove the breather on the curved pipe on the LH side by the clutch pedal and fill through the vent pipe, check immediately after shutdown as converter drains back and will read overfull when checked after a long shutdown. I have my own method for checking them which is to check it running, If you want to do that you MUST make sure the tractor is immovable. Put the tractor in high range , high gear and start and let idle for a couple minutes, check and add till full. The reason I do it that way is that with the drive in gear there is no gear splash to cause inaccurate readings and all the system is in operating mode, Later Case systems recommended this and I simply applied it to the older systems.
