Hi guys I'm looking for some help with my 2090 remotes. Problem is when I go to use the remotes for the first time they have no pressure on either set. I've installed a gauge at the remotes and I can see the needle pulse when I pull my lever but then back to 0. To get the remotes working I have to throttle up and do a combination of lowering and raising the 3 point hitch and running up and down the three speeds in the power shift. After about a minute of this the remotes will start working and I have 2400psi and can cut hay all day and it's fine, turn the tractor off or let it idle for a while and I have to do this all over again. I've got 20 psi at idle from the charge pump and 30 psi at pto speed. I had a local case guy had me plugthe steel line that comes off the remote control valves under the cab and plug the hitch line at the compensator and check for signal pressure at the remotes. I got 300 psi with the tractor at pto speed but 0 at idle. Not sure where to go next , any help would be great. Thanks
