970 Case PTO seal replacement
Depends on what seal is leaking. Two speed PTOs had more than one. The outer seal that you can see is easy. Just drill a couple of holes in seal flange and put screw in it to pry it out with a claw type tool. If oil is leaking around splines of pto shaft itself you are going to have to go deeper and remove pto housing.
Loren
