Broberts459
New User
Been a long time reader of this site and have learned a lot from you guys so I finally decided to join. This is my first post.
I've got a 2290 case tractor with about 7500 hours.
Early on it was used for small tillage work. For the last 3000 or so hours it's been used for mowing hay with a 10 foot JD disc mower, and round baling. No stationary pto work.
WORK THATS BEEN DONE to it include.
Drive components for the hydraulic pump, new torque limiter about 1000 hours ago.
Replaced hytran hydro fluid, both high flow filters, cleaned suction screen all about 2 years ago.
SYMPTOMS: Tractor won't move in any gear or powershift. Gearpump has been noisy for a while now. It's gotten progressivley worse over time. Remotes work. PTO works, 3 point arms lift. Steering and brakes work.
Tractor is supposed to surge when clutch pedal is depressed all the way and it no longer does this. Clutch pedal does nothing when depressed. You can put the gear selector in any of the four gears and nothing happens when you release the clutch. You can actually put it into gear with out depressing the clutch. the reverse lockout still works however.
I've purchased a complete service manual for the tractor.
TESTING: I tested all clutch packs in all power shift positions and c1, c2, c3, c4, and lube all tested good according to manual specs at both idle and high idle. Tested regulated pressure at the clutch regulator valve and it was 170 at idle and about 180 at high idle. Clutch pack pressures were as follows:
Clutch Released:
low idle Lub- 55
highidle lube-60
LOW IDOL PSI READINGS
ps1 Clutch pedal in:
c4-170
Lube-0
PS1-slowly Releasing cluch
c4- dropped to 0
Lub-rose to 55
Shifting from ps1 to ps2
c2-dropped to 0
c3-rose to 170
lube-55
c1-170
Shifting from ps2 to ps3
c1- dropped to 0
c2-175
c3-rose to 170
lube-55
pressing clutch pedal in while in 3rd ps
c4-increase to 170
c3-dropped to 0
c2=dropped to 0
lube-dropped to 0
clutch pedal in shifted to Reverse
c4- 170
Slowly released clutch pedal in reverse
c2- 180
lube 55
c4-170
No pressure registered on gauge from test port at line between charged pump filter housing to the high pressure pump. Oil in that line is extremely foamy when I remove the test gauge from that port.
I raised the 3 point arms while going through the powershifts and the 3 point arms rose at a good steady speed in every power shift. It doesn't appear there are any major leaks in the clutch packs after these tests. However when I press the clutch pedal down while raising the 3 point arms the hydraulic pump circuit (probably the gear pump) whines, the 3 point arms momentarily stop, studder then resume lifting at normal speed. This is the only time the 3 point arms or remotes studder.
The clutch valve spool on the power shift seems to be seating all the way down into the valve body when the pedal is released. Travel is a little over an inch.
I think i have multiple problems going on. I think I have poor charge pump, or restricted filters and also hung up valve spools somewhere.
Any and all help would be greatly appreciated. Thanks for taking to time to read this. Hope the details help
Clutch Released:
low idle Lub- 55
highidle lube-60
c4-170
Lube-0
c4- dropped to 0
Lub-rose to 55
c2-dropped to 0
c3-rose to 170
lube-55
c1-170
c1- dropped to 0
c2-175
c3-rose to 170
lube-55
c4-increase to 170
c3-dropped to 0
c2=dropped to 0
lube-dropped to 0
c4- 170
c2- 180
lube 55
c4-170
