I am the new owner of what I think is a 210HB. This machine has a front bucket and full backhoe. I have the gasoline engine running OK now and the hydro for the front bucket seems to work well. The clutch pedal is right on the floor and flops up and down. There is only a small viewing port under the starter and I can't see much there. The shifter seems to move into each gear but I get nothing. Like it's stuck in neutral. The hydro pump for the backhoe that is on the PTO shaft doesn't make any pressure and doesn't get warm while the tractor is running. Doesn't seem like the PTO is spinning. I have seen some other posts on clutch plates stuck to flywheels and tractors stuck in gear, I guess I have the opposite issue.
I would like to ask the forum for suggestions. Thanks in advance for your help. Josh Gallagher
I am in the Portland, PA area. If there is anyone close, I would be willing to pay reasonable rates for help onsite.
