336 case engine,, 870 tractor
trak
anyone know if you can safely put a turbo, and turbo pump from a bdt engine on a regular 336 from an 870? thanx
You can.
The 336bdts had small journal cranks and a oil pump mounted on the front main. A lot less revolving weight, and parts. The balancer/oil pump in a large journal 336 could become an issue.
If you have a doner 336bdt, why not use the whole engine.
Loren
I may have a donor 870 bd engine... front pump? my bdt had the balancer pump,, I tried a front pump,, I don't know what I really did wrong, used it on one lil job, then it blew up big time, #1 rod cap bent and twisted, block cracked so bad it bent the pan
