case 3300 plowing
Reading the comments it looks like a rebadged Oliver plow. Either way it?s a beautiful combination with the 6030.
That video has been on here several times in the last 5 years, and that IS NOT a 3300 plow.
It is an OLIVER/WHITE built plow. Labled as a model 400 in the Case lineup, with either shear bolt or trip beams. It is not a hydraulic reset plow, which the 3300 plows were.
I thought we got you straightened out on the difference between CASE built plows and OLIVER/WHITE plows, but I guess not.!!!
Loren
i bought an operator manual for 3300 powr-set(hydraulic) plow on ebay & checked it out. front cylinder is different and no hand adjustment with on land, so you are correct. my plow has white 549 moldboards that were added.
After Case started marketing Oliver/White plows they offered conversion O/W Radex bottoms that would bolt to Case beams, thru the parts system.
Loren
Around here the only time I saw green manure plow down was in the early spring after a hay field had gotten abought 6 inches of growth or in the fall after some regrowth from last hay cutting. While that gentleman is definitely adding organic matter to the soil, all that grass looks tall enough to be headed out. He is planting a lot of seed. What I don't know about green manure plowdown are the benefits other than organic matter. It will use up nitrogen to decompose/breakdown, but will it also add nitrogen, creating an overall positive for the new planting??? gobble
The idea of green manure was to plow under young legumes, such as clover or alfalfa, to provide N into the soil for your corn crop. That is mature grass that will definitely require N to decompose all of that mess.
Well whoever built it,it's bury the trash pretty well, as a kid we always plowed down sweet clover,now that was in the later 50'S, we had a John Deere, and a Oliver plow,and they never did that good of a job of covering it !
