Case 970 cab removal
Was wondering if the cab on a 970 case can be taken off
without be cut, it looks to me like the cab fits around the
platform that the open stations would use, the floor is part of
the tractor so therefore the cab could be taken off and open
station fenders could be put on, right? Thanks.
No cutting required, once all is disconnected the bolts along the bottom hold it. Have a good lifting setup.
You need to open up your eyes and get your wrenches out and use them, and remove all the perimeter 3/8" bolts side and rear. The only thing you need to disconnect is heater hoses, AC fittings and the wiring harness connection. Cab will lift off platform with no problems.
Open station fenders will bolt on in 2 positions, high and low depending on tire size using same bolt pattern.
Loren
wow ad case is right . how would they build it with no way to get it off..? you gotta cut the hood off too.lol
Well on a 90 series case you can?t take the cab off because the floor is part of the cab so if you were to take it off there?s no platform, pretty sure you have to cut the cab posts. Could be wrong but that?s what I?ve heard
