Eagle Hitch Adjusting Screw Stripped.
fixer2u
Hey Case friends,
My threads on my adjusting screw are stripped and will not longer hold my brush hog up. Is there a way to salvage this or do I have to look for a replacement?
Thanks in advance!
Nick
I had that issue on my 530 and I went to a local truck spring repair shop, they have good high tensile steel rod with long threads for spring shackles, it made an excellent repair, If the internal threads are good in the upper gear that would make you an excellent repair. It is a bit more expensive but the material quality I believe to be better.
Thank you all for the reply. Looks like I have options!
Jeff I sent you an e-mail.
Thanks again guys!
Nick
Can anyone tell me what the thread count is on one of these? I have gone to a half dozen places locally in search of threaded rod, but no one has anything close. It appears to be 3/4", but how many threads per inch?
Thanks.
Nick
(quoted from post at 12:12:45 05/17/18) Can anyone tell me what the thread count is on one of these? I have gone to a half dozen places locally in search of threaded rod, but no one has anything close. It appears to be 3/4", but how many threads per inch?
Thanks.
Nick
I was wondering where anyone found fine-thread rod of any diameter, let alone 3/4. Should be 16tpi. I had to shorten the non-adjustable side of my hitch, it appeared someone replaced it with one too long, I could only adjust the hitch height to about 6" off the ground. Put a 3/4 fine die on the rod first, chopped off about 2-1/2", ground a chamfer on the end, cut the threads further down the rod, took the die off (cleaning up where I ground the chamfer), and put the whole shebang back together. Worked great. I was able to borrow the necessary 3/4-16 die. If you plan to cut more than 2-3" of thread, I recommend you pay a machine shop to do it with power tools; that was too much like work.
Isn't the threads on the actual part left handed. If I remember right I had a hard time finding a die to thread the rod I used.
(quoted from post at 20:07:21 05/22/18) Isn't the threads on the actual part left handed. If I remember right I had a hard time finding a die to thread the rod I used.
ust went out & checked. Yup, on mine it sure is. Game-changer for sure!
On my early 530 it was definatly 3/4 HF RH, I used regular shop tools to do the threading I needed to do, as before, a spring shop had heavy spring shackle rod with long threads, could not tell from factory once welded cleaned up and painted.
That's interesting. I had to use a 3/4" 16TPI left hand thread on my 59 210B. I wonder why they made them different. It appears fixer2u is left handed too from the picture he posted.
I buy a lot of stuff from mcmaster carr, shipping is fast and quality is always good. they have left hand thread fine thread 3/4 rod for 18$ a foot.
