Case Unit Planter Parts?
GM Guy
Hey all,
A friend of mine who really enjoys Case found himself a Case Unit Planter, 6R30 setup on 3pt bar, to put in some milo this spring.
He is in need of a few parts, and I was curious if any of you guys might have any.
The main holdup is a 9 tooth sprocket for the #32 chain.
If you have one, let me know how much.
Thanks!
Post a pic, if not that a part number. Also where is the gear. I have a parts planter, but it is a 4 row driven from the lift wheels.
Probably have one here...location?? Have several Case planters with the K-160 units. Does it look like this...
Hi,
Yes, it appears to be identical to the 6 row shown (except no gandy boxes)
It does drive off the row unit tire.
I will ask him again, but I believe its directly on the back tire axle shaft. Is there a jackshaft? it might be there as well.
