320 CASE CRAWLER TRACK CHAINS
RJZAMISKA
Has anyone had any luck with installing new pins and bushings on 320 track chains??? Or does anyone know of where good replacements can be found for the lower end,
chains, pads, idlers and sprockets??? The last part of my restoration seems to be the hardest part to complete. Regards RJZ.
If the chains are not worn to thin on the bottom there are companies that specialize in pin and bushing replacement. Here they come and pick up and return them when done. You may want to check with a local dealer that sells crawlers and services them. There are aftermarket outlets for undercarriage parts, on that comes to mind is Berco, they make chains, sprockets, idlers and bottom rollers or most crawlers, unfortunately you are into the expensive part of owning and maintaining a crawler, good luck
