Before and After
1370rod
I was able to finish the cab interior today and run the 1070 on the dyno a couple hours. Runs great and turns out a respectable 110 HP. No leaks or problems turned up while running. After operating temps were reached I ran a test on the hyd pump and remote valve. The pump tested OK but the remote valve has a couple leaking check valves and needs pressure set up 400 psi. Rod.
I do love before and after pictures. Rod, it sure looks sharp, good quality work. Amazing at its age she has rated horsepower.
Looks great Rod. Now you will have to take your boots off before you drive the tractor, LOL.
Kow Farmer Kurt
You are a true craftsman, I admire your work and skill. Are you going to use it or keep it around to look at?
Rod, My 1170 needs a similar redo on the inside of the cab. Did you start with a kit? If so, who makes the kit? Thanks.
Don that molding around the dash was standard equipment on the earlier tractors. It is getting hard to find good pieces as many got thrown way or damaged. Rod.
