Case SC Splitting Pins
C.Amick
I know this topic has been listed before, but my search didn't bring it up. What is the recommended diameter and length for splitting pins? I need to replace my flywheel starter ring gear. Also, what's the best way to support the tractor halves? I thought about some sort of transmission jack, see link.
Transmission Jack
Your splitting pins are 3/4" diameter x13 and 11/16 long. I drill an 1/4 " hole 1/2" in from each end and insert 2 cotter pins. Material is carbon steel.CM
This might help
<image src="http://forums.yesterdaystractors.com/photos/mvphoto14019.jpg"/>
Thanks for the info. Looks like it is not necessary to support the front half with anything other than the pins.
Why is the length measurement so precise? I don't see what they would hit if they were a little longer?
I?m sure like anything there?s a beginning and an end to everything. But like I described will be more than adequate, but if I were to speculate, making them too much longer, they would probably bend under the stress. CM
