I am searching for a domestic source for David Brown clutch parts. New or rebuilt.
Received a quote of $900 to rebuild my DB885's clutch. More than half the amount, over $500 is for rebuilding the pressure plate. Eighty some bucks each to reline the disks which compares with what I have seen online. Forty to surface the flywheel which seems fair. Included are new T.O., pilot and P.P. bearings.
I can find clutch disks and bearings online but not a pressure plate new or rebuilt. Will need trans top gasket and trans to differential gasket. Seems like I spotted them online once before but no luck tonight. Tractor is missing one of the T.O. bearings little spring thingys that look to be used to prevent wear from the forks rollers, so I will need at least one of these too.
