Hello everyone,
I have a case 530CK with the gas engine with roughly 140hrs on it since a complete rebuild.
The tractor was running perfectly until i had it floated to my new lot. I loaded the tractor on the trailer no problem. The next day it arrived to be taken off started fine came off the trailer fine. Started up my driveway a 8-10% grade and it started cutting out and stalled.
My thought when it happened was that it was low on gas and the incline caused it to sputter and die. Looking back this doesn'[t make the most sense unless it was completely empty because the fuel line leaves the tank close to the driver position so an incline would push the fuel back to it.
That being said I filled the tank and had the same issue. I ended up having to tow it up the driveway. No up on flat ground it starts fine idles fine but under load it sputters and seems like fuel starvation to me.
I have taken everything except the carb apart replace the fuel filter and fuel lines. Could have i sucked some debris from the bottom of the tank into the carb causing the issue?
Any other suggestions would be great.
