Kevin in Iowa
So I just picked up a Case VAC, I have a service manual ordered, but in the meantime I'm wondering if you all could help me out. Not sure of the year yet but it does not have an eagle hitch or 3 point, so not sure what year that makes it? (I haven't looked for a serial num yet, where might that be?) Anyway I'm wondering what type and where to add rear end fluid? Second question is regarding hydraulics, it has a belly mower and wont lower, the cylinder is free, I can make it drop by unhooking the hose at the cylinder. I see two rectangle head bolts at the rear of the pump, (which is mounted with the gear drive on the right side of the tractor) I took them off, I see a spring in one (the bottom one) and no spring in the other (top)? I assume there is a valve in there that is sticking or something? Am I on the right track by cleaning out these two ports or is there somewhere else I should be looking? thanks
