Got the DC4 running yesterday after 3 years sitting in the shop for painting. I went ahead and rebuilt the engine while I was at it this winter. Put
gas in the tank and installed a new battery and she fired right up. Well almost started right up. I pulled the light switch instead of the kill button
🙀. After I figured out the right switch she fired up but wanted to run full throttle, did not want to idle down. I finally figured out today that the
lever on the carburetor that the throttle linkage hooks to was loose on the butterfly shaft. I have a spare carb so that's a simple fix. Then I
noticed the oil filter canister was leaking oil, the gasket had moved on me. No real problems, but then while running it a few minuets it spewed
out 2-3 gal of water? Pulled the thermostat thinking I might have ut it in backwards but I had not. Put it back together, filled it with water and
everything was fine. It must have had some air trapped in the system. Dick.
