connor9988
- Location
- Central Iowa
Slowly finishing up a project for my 2 tractors. Now my wife or I can ride shotgun around the farm. This is a quick pre-fit with some more modifications to come. But as of right now it is solid and sturdy. I will build a second axle bracket for the 300 in time. It is meant to be removable so I can swap it between tractors. I used heavy angle iron as a base with a 2" receiver hitch welded to it. This bolts to the axles in the same manner as the fenders. The seat post is 2" square tubing with 1/2" flat stock welded to the top which the seat is bolted to. The axle clamp bolts will get lock washers and lock nuts for extra protection. Hopefully the safety police do not come after me. I do not intend to set land speed records with this seat nor do I intend to do rock climbing with it. Just wanted something to scoot around on with my wife.
As a final note on the seat I will be adding more reinforcing between the flat steel and the seat post.
I am also popping in a dealer decal the I spotted a few days ago for those who are interested.
