Case SC radiator cap
A few years ago I did replace the original gasket with a new cork gas cap gasket as they are the same size. I was wondering if anyone made a replacement for the tabs that lock into the radiator neck?
oops ,.. a cork gasket will probably fail you ,,. ChucK is so rite about a rubber gasket ,,. if your tabs are gone or very poor ,.go to your favorite radiator shop , junk yard or even NAPA ,, Nothing wrong with new parts.LOL ,the SC ornament can be placed on the NEW Cap with a little engenuity , Although I never put a lot of thought to doing it .
I cut one out of a 1/16" thick piece of brass stock, bending the ears a little to make it easy to engage. This has served my model S for many years without rusting out like the steel original. I cut a gasket out of rubber gasket material.
I removed the little flat strap and put it on up side down. The cap fits much tighter.
Thank you for the replies.
