Ranchingelec
I have a 1070 with power brakes. Left brake will lock up the wheel no troubles, but when right pedal is pushed the wheel will not lock up. Now here's the trouble. When right pedal is pushed, it is like there is a loss of oil pressure to the clutch. The tractor engages power and disengauges power to the rear wheels like I was pushing the clutch peddle in and out. No visible outside oil leaks. But what could have "inner" oil leaks? Hytran oil, daily feeding tractor, it's been a year since I did a rps34 rebuild because the clutch hub bolts broke. Just noticed the brake issue yesterday. Any ideas??
Ranch.
Ranch.
