water pump help
Fordguy93
New User
Hey everyone, I just purchased a 1965 Case 530 CK last weekend. The tractor is in overall good shape but the water pump leaks like crazy. I had it hauled to my property and plan on removing the pump this weekend. However all I will have is the tools in my truck that I bring with me so I was looking for a quick run down on pulling the pump just so I don't run into any issues. Thank you for the help in advance!
pretty regular stuff, 7/16,1/2,9/16. wrenches&sockets to get the tin off, 9/16 wrench to get the bolts that go up into the radiator from the bottom. long screwdriver to get the radiator hose clamps off. 5gal bucket to put the antifreeze into. maybe a hose or chunk of eave trough to go from the radiator drain down to the bucket. there is a drain on the side of the block with a 5/16 square hole in it that probably won't come out unless you have a torch but its ok because there is a drain on the bottom of the radiator that may or may not open. if it opens you will probably need some wire to jam into it to clear it out. gasket scraper and wire wheel to clean up the gasket surface under the pump. it's an easy job. sort of sucks working through the jungle gym of a loader unless you can raise it all the way up and put a piece of angle iron along side of the lift cyl rods to be safe under it incase it drops.
Thanks for the info! I just got it pulled out. Ended up leaving the radiator in.. there was no way I was getting to the bottom bolts. It was a little time consuming but I was able to slide the pump out between the motor and radiator.
