jim_uny
with rps-34 70 series, if you park tractor shut off & leave in gear with park brake OFF on an incline will tractor stay put ?
ok. if maintained, does parking brake work aok ? when tractor running & in neutral does tractor stay put ? how do you adjust if it moves slowly forward ? thanks
When the brake is released you should be able to tighten the end of the handle to tighten the brake. First make sure the hydraulic brakes are set up properly as that setting will effect the parking brake also. Make sure the light in the dash comes on with the parking brake so you do not drive away with the parking brake on. When you set up the brake set it up so it is tight enough so it is obvious that the brake is on. Driving with the parking brake on is the easiest way to trash the brakes!!
Engine should not have enough power to move the tractor when the brake is set. If it will move at all, sooner or later you will forget the brake is set and trash the brakes.
loren - i re-read case manual on rps-34. the flow diagrams are excellent for showing low (1) med (2) & hi (3). i dont understand what those clutch packs are engaging or disengaging ? is it a geared shaft within a shaft that results in 3 varying speeds. you could just point me to a page in book ii would be aok. thanks
