Neil Grant
I have this tractor and the manuals for it. There seems to be well referenced in the owners manual that there is a optional high speed 4th gear which correlates well to the parts manual showing a different set of gears fro 4th gear with the optional high speed 4th gear. I am told this is designated by H after the serial number. All the other gears are the same and there is no reference to an optional low speed transmission anywhere in the owners manual. Every gear is the same clutch to back wheel in the normal tractor save the optional high 4th gear one.
If the L does indeed mean low gearing, is it simply all tractors without the high 4th gear? if is is a special lower than standard speed transmission, how do they do it? I cannot see how. And my tractor seems to move about at the standard speed. Trying hard to understand. Thanks in advance!
