mEl
Location
NC PA.
Friends, I need any and all leads on a 930 gas carb, I have a friend in need of one. Please post back if you know of any sources.
Thank you. Mel
A friend of mine just sold one to a guy I know the
other day for his 930, I know he has parted out
some other gas tractors, I'll check and see
Ben
Do you have a brand and model number? I got some carbs in a box at a sale, won't work on anything I have maybe I can help someone out. gobble
Threadwell Carburetor 4870 County HWY 14, Treadwell, NY #13846 phone 607-829-8321 might be worth a try. They have helped me out in the past with parts
etc for this type of carburetor and seem to have all sorts of items.
A long shot but I hope it helps you out.
Let us know how you make out.
Best Wishes,
FarmerHR
This number is for a place that has carb parts 888 871 2272. I have never had to use them. If you needed a carb plus all the rest of the tractor I could help you out!! Maybe Elmers repair would have some ideas too.785 857 3248.
Mel, I would have to go out and get the brass tag #'s off of mine. I know it is a Zenith, a JD 7700 gas combine carb is very similar.
Brad
(quoted from post at 14:27:43 03/04/18) Friends, I need any and all leads on a 930 gas carb, I have a friend in need of one. Please post back if you know of any sources.
Thank you. Mel
I don't know if this will help you out or not. I have a friend that uses carburetors from 9 cylinder rotary aircraft engines on his G1000 and GVI Minneapolis Moline tractors. I can ask him where he gets them if you are interested.
L thank you , I need a stock carb, it will end up on a puller I am sure to satisfy stock appearing rules but probably heavily modified internally.
(quoted from post at 02:20:55 03/07/18) L thank you , I need a stock carb, it will end up on a puller I am sure to satisfy stock appearing rules but probably heavily modified internally.
That's what my friend does with his Minneapolis Moline's. The only thing he has done to the engine is have the cam ground and the aircraft carburetor. He does really good with that setup.
Yes, those carbs are huge and MM made some 800 CID engines that are a direct bolt in. They do run well.
